Intralink 3.4 Error Launching Browser?
  • August 8, 2011
  • 2 replies
  • 3081 views
Hi.
This doesn't belong under Windchill, but there's nowhere else to put this question that I've found.
We've recently lost our Intralink Administrator, and when I click on the Help menu, and select Pro/Help, I am greeted with "Error Launching Browser" message.
I'm at a loss as to where to start looking to fix this issue, if anyone has some suggestions, I'd really appreciate it.
Nathan
Best answer by DanielSinacki
Hi Nathan,
First start from client installation.
Start ptcsetup under /installation/proiclient3.4/bin
Installation wizard should pop up, click next until you will be on step "Optional Configuration Steps"
1.Check box called - Web browsers location
2.Next
3.In Web browser location (window) specify the path (keep in mind that all PTC software has issues with "spaces" - this might be the problem.)
4.Finish the installation
After that help should work. Inform me about the result?
Hi Nathan,
2.Next
Thanks Daniel,
In fact, there was nothing in the help path.
This path worked "C:\ptc\proiclient3_4\html\usascii\intralink"
