Intralink 3.4 on Win7 with new domain - FIXED
Hola -
We've been running 3.4 M062 on Windows 7 for a while. Edited the .bat file for the "Dsun.java2d.noddraw=true" stuff and all has been well.
There is now a new problem.
We've switched domains, so that the user is now a domain and not a local user. When I start intralink, I get the splash screen and then it dies. The .proi.log file shows "java.lang.NullPointerException null". This may or may not be the problem.
So, with the same workstation and batch files, if I logon as a local user and run proilink3.4.bat, Intralink starts and runs normally. If I logon as a domain user, Intralink's splash screen appears and then dies and it Intralink does not start.
The Intralink server is now on a different domain as the workstation, but I can successfully ping both ways either by hostname or ip address. I've also tried changing tnsnames.ora from the server's hostname to its IP address with no success.
Running out of ideas here....
TIA
