Issue with Indexing services (Indexer) start
  • October 8, 2012
  • 0 replies
  • 547 views
We are currently on Windchill 9.1 M050 using Fast Instream to index the contents. Our Indexing services (Indexer) are failing to start after the weekly system restart with the following error message. When it failed previously, we had to restore the index data files on the index server. This doesn't seem to help this time.
Have anyone encountered this problem? If so, how did you find the solution?
[2012-10-04 15:38:54.008] CRITICAL index_producer_0 Committing a graceful exit with status code 1 because '_size < _max_size' [mergeocc.cpp:863]. A monitoring oracle will restart me.
Rick Deutsch
Sr. Administrator, Windchill Team
Global IT
St. Jude Medical
This communication, including any attachments, may contain information that is proprietary, privileged, confidential or legally exempt from disclosure. If you are not a named addressee, you are hereby notified that you are not authorized to read, print, retain a copy of or disseminate any portion of this communication without the consent of the sender and that doing so may be unlawful. If you have received this communication in error, please immediately notify the sender via return e-mail and delete it from your system.
