Issue with seeing comments from workflow
Hello
I was wondering if any of you had any ideas on how to sort out an issue that I am having.
I have a pretty simple review, approve release workflow that is initiated every time a certain type of object is created.
Now when it goes through the default type activities in the workflow you can add a comment in the comment field and select a routing.
What I am having a problem with is the fact that these comments, which should be showing up in the process status section of the task but they only appear if you are an admin and I need them to be there for standard users.
Is there also a better way of communicating changes/comments on a standard task to the next user in the cahin other than this process.
Bear in mind that I am not a developer and have limited Java knowledge. I just utilise the configuration tools to help me get thesystem up and running.
Thanks in advance
Oleg
