Iteration and Revision
  • November 4, 2014
  • 2 replies
  • 5432 views
Hi!
Can somebody explain to me what is the difference of Iteration and Revision in windchill?
Thanks in advance!
Version = C.4
Revision = Index = C
Iteration = 4
Iteration = Checkout / Checkin
Revision = Revise after e.g. Release
Hi Luar Joy,
I am explaining Bjorn's answer briefly.
Version has two parts. Revision and Iteration.
example: sample.prt B.3
B.3 is the version where B is the revision and 3 is the iteration.
when a small change is required, we check out the particular part/document perform the change and checkin. The version changes from B.2 to B.3. This doesnot require an approval or release.
when a large change is expected, which undergoes approval from respective team, there occurs a revision. The revision changes from B.3 to C.1. This requires approval from the respective team.
Rajeshkumar Balaganesan
