Java 8 Client Supprt
  • October 15, 2014
  • 9 replies
  • 1860 views
Seeing as Oracle is now pushing Java 8 Update 25, I was wondering what the official position is on client support? I am particulary intereted in Windchil 10.1 M040 as we will be at that version for a while yet. I'm also sure our security organization will be demanding we upgrade the client JRE regardless of what PTC officially supports. So, I'm also wondering what affects we might expect if we are forced to upgrade.
Thanks in advance.
Have a nice day!
Craig
Java 8 client support is being pursued for 10.2 M030.
This may well also need to be provided for 10.2 M020/M022 and 10.1 M050.
It seems doubtful that it would reach 10.1 M040, however -- as the
testing time/effort (and potentially patching) required to support a new
platform version is usually only applied to the latest available MOR.
[There are, of course, lots of fixes in M050 as well that one should
have...]
craymond12-AmethystAuthor
Thanks Jess.
So I guess the bottom line is we need a few guinea pigs to test all the applets to see what happens.
Moving to a higher release would be nice, but as always it is a cost and resource issue.
Craig Raymond
Windchill / Web Developer
BAE Systems
Enterprise Shared Services
ES Eng Tools
1098 Clark St
Bldg. 46, Fl 2, Grid D44
Endicott, NY 13760
One note:
Java 8 changes the Java Plug-In security model once again.
As a result Windchill applets will not function under the Java 8 Plug-In
unless/until RMI tunneling is enabled on the server -- as the Java 8
Plug-In itself rejects direct RMI communication attempts.
Currently I have it working in IE 9 (the lifecyclemanager applet loads - haven't done any serious testing yet). I had to add the following to our company xconf that is included in site.xconf
<property name="wt.rmi.clientSocketFactory" overridable="true" targetfile="codebase/wt.properties" value="wt.boot.WTRMIMasterSocketFactory"/">
Firefox isn't happy with our internal certificate path for the deployment.jar, not PTC's fault just something I have to sort out.
Chrome won't load the java plugin for some reason, haven't figured that out yet. Maybe because I'm on the dev change at version 40?
Craig Raymond
BAE Systems
ES Eng Tools
1098 Clark St
Endicott, NY 13760
If you're using a deployment rule set, then you will have things to sort
out if you're not using a certificate purchased from a certificate
authority that is trusted by the Java Plug-In.
As for Chrome, at some version in the near future they are simply
dropping all support for the entire plug-in API upon which the Java
Plug-In is based -- at which point it will no longer support applets.
> <property name="wt.rmi.clientSocketFactory" overridable="true" <br="/>> targetFile="codebase/wt.properties"
> value="wt.boot.WTRMIMasterSocketFactory"/>
> *Craig Raymond*
> BAE Systems
> ES Eng Tools
> 1098 Clark St
> Endicott, NY 13760
> Work: 607.770.2349, Mobile: 607.221.1421 Fax: 607.770.3594
> *From:*Raymond, Craig (US SSA) [
> *Subject:* [solutions] - RE: Java 8 Client Supprt
> new platform version is usually only applied to the latest available
> MOR. [There are, of course, lots of fixes in M050 as well that one
> should have...]
I've seen that it's dropping NPAPI support, but Firefox shows a "Next Generation ..." plugin. I thought, perhaps incorrectly, that the newer plugins weren't based on NPAPI? I don't seem to see anything in my searches as of yet on what version of chrome NPAPI goes away permanently, just mentions of it being this year.
Since I am on the dev channel are 40 something, it certainly is possible that Java support is dropped at that version.
Craig Raymond
BAE Systems
ES Eng Tools
1098 Clark St
Endicott, NY 13760
18-Opal
October 16, 2014
I know the document upload applet won't work. One of the guys here ran into that on Monday. No workaround to get it going either. Choice was to downgrade java back to 7 or switch to using basic browser functionality.
-marc
I'm pretty sure that the document upload applet does work in the latest
Windchill versions with Java 8, i.e. that's not one of the compatibility
issues I noticed (once RMI tunneling is enabled).
The "Next Generation" Plug-In shown in the Java Control Panel is now
pretty old news. It doesn't change whether NPAPI is used.
My understanding is that:
1. Chrome's new Plug-In API doesn't allow one to do the sorts of things
the Java Plug-In needs to do
2. Oracle has no plans to make any attempt to use the new Chrome
plug-in API
* Perhaps due to #1, perhaps not
Jess Holle
> Generation …" plugin. I thought, perhaps incorrectly, that the newer
> *Craig Raymond*
> BAE Systems
> ES Eng Tools
> 1098 Clark St
> Endicott, NY 13760
> *From:*Jess Holle [
> *Craig Raymond*
> BAE Systems
> ES Eng Tools
> 1098 Clark St
> Endicott, NY 13760
> Thanks Jess.
> *Craig Raymond*
> BAE Systems
> ES Eng Tools
> 1098 Clark St
> Endicott, NY 13760
> *From:*Jess Holle [
> M050.
> a new platform version is usually only applied to the latest
> available MOR. [There are, of course, lots of fixes in M050 as
> well that one should have...]
