JRE authentication problem
  • February 16, 2010
  • 0 replies
  • 467 views
We are having trouble with using JRE 1.6_04 and higher on our clients accessing a Windchill cluster. The cluster is composed of several app nodes in a BigIP pool that uses a separate domain name. The symptom is that users are being prompted for authentication by applets many times. It appears this is related to a change that was done to the JRE:
