Limits on search results
What govewrns the number of search results returned in Pro/Intralink 10.0?
I used to be able to search in 9.1 and get a complete set of results regardless off what I was searching on, for example all .drw files in a given context, which may be > 50,000.
Any search I do now is limited to about 2000 - 2100 results. Two settings I have changed are the preference for Tables --> Size Limit (to 100000) and the server property "wt.pom.queryLimit” to -1, which I believe means that an unlimited set of results should be returned.
I don't have access to Query Builder (I don't believe) so I have to use standard searches for getting what I need.
Hopefully someone can enlighten me on this.
Thanks in advance for any advice..
