Log filenames being checked out/in in the WC log files
  • November 11, 2014
  • 690 views
Is there a sertting that can be enabled to show the name of the file that is beingsaved, checked out or checked in in the log files? One of my users syas he has lost some work and is positive he checked the files in. If this information was in the log files, I could verify if he did or not in the future.
You can enable Security Audit Reporting for check in/ check out and delete. You can generate the report using Site> utility > Security Audit Reporting . Check more details about auditing in help center below are some links
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=AuditAdminAuditEventRecordConfig&action=show
http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=AuditAdminSecAuditReportAbout&action=show
Hope it helps !!!
Shreyas
