Memory Leaks on Windchill Application server
  • November 7, 2014
  • 2 replies
  • 946 views
To all Admins,
I need some help to determine if I am having surviving generations problems which is generating leak issues in my system. I am running Windchill 10.1 M020. I found the NetBeansIDE tool which can profile the system to find which class is causing the leaks, but I cannot get it started.....just dont know enough about it or JAVA....I would appreciate anyone who has experience with this software or another method to determine where these leaks are generated. We have 32GB or RAM on our server, and it is at 31.7 most of the time it is up, unless I reboot the server, then it releases the generations that have been held over from garbage collection.....just need some help from a JAVA guru on this one.
Thanks in advance!
Buddy Hudson
There are known SPRs and patches for this. Contact technical support to get
them and apply them ASAP.
Hey Thanks David, will contact them right away....
