Migration issue –objects listed twice. Objects not migrated.
  • August 26, 2010
  • 0 replies
  • 333 views
We are migrating from ILINK 3.4 M062 to PDMLink 9.1 M050 – migration tool did not transfer some objects from old system to PDMLink. After some investigation I noticed that in old system there are duplicates of “hashed” files(physical names used by database not CAD names). I know that there should be one and only one hashed object with the same name. The duplicates are in different folders on Unix box so my guess is that past vault moves maybe caused this issue. Have you encounter similar problem and what would be the best approach to validate that what is left (did not get transfer) in old system is not needed in PDMLink?
Thank you,
Artur
