Jun 6, 2022 9:44 AM UTC
Modifying the LDAP search scope Windchill 12
I need to move my users to a new OU in AD, Our current Windchill installation uses AD to authenticate the users using an LDAP adapter.
Using Info*Engine I have changed the Search base value in the current adapter to reflect the new OU in AD and ran the ​ant -f webAppConfig.xml regenWebAppConf command from the Windchill shell, however when I move my users to the new OU they cannot login to Windchill.
I must be missing some steps to get this working, any help would be appreciated
TomU
TomUAnswer
Jun 7, 2022 10:10 AM UTC
I should also add that the ant command is only needed after changing the Apache config.  It has nothing to do with Info Engine changes.  For those to take affect you need to restart Windchill.
Jun 6, 2022 1:40 PM UTC
You can use a tool like JXplorer to test your LDAP connection. You can connect with or without a Search base in order to validate that it is correct.
http://jxplorer.org/downloads/users.html
You may also need to check your filter:
......windchill.mapping.user.filter:
Peter...1-VisitorAuthor
Jun 6, 2022 3:02 PM UTC
I forgot to mention that we are running Windchill version 12
The Directory system agent user does not change and I can still browse the AD structure using this account after I have made the change to the search base.
It is when I change the search base using the Info Engine utility from
ptcProperty: xxx.xxxx.MSADLdap.searchBase=OU=Restricted,OU=User,OU=XXXXXXXX,OU=XXXXX AND XXXXXX,DC=XXXX,DC=XXXX
to
ptcProperty: xxx.xxxx.MSADLdap.searchBase=OU=Restricted,OU=User,OU=XXXXXXXX,DC=XXXX,DC=XXXX
I then ran the ​ant -f webAppConfig.xml regenWebAppConf command from the Windchill shell
but after this change users can no longer login to Windchill.
Where do I find the ......windchill.mapping.user.filter:
Jun 6, 2022 3:31 PM UTC
It's in Info Engine, in the Additional Properties
Something like:
Property: local.EnterpriseLdap2.windchill.mapping.user.filter
Value:
memberOf=CN=WCUsers,CN=Users,DC=company,DC=local
