Mozilla browser
  • May 26, 2014
  • 12 replies
  • 2791 views
We've recently been using the embedded mozilla browser due to what seems like constant ie/windchill annoyances. One of my users sent me this, does anyone have any advice?
> The Mozilla Browser is not working to “Collect Related Data”. For example, if I select a generic model for checkout I should be able to collect all the related instances of that model, but when I try the interface just sits there spinning . . . . . . other users have experienced the same thing.
Ian Bagnald, CISSP
Sr System Support Analyst
Windchill:
We are using 10.1M040 which officially supports IE8 and IE9. We found later versions not to work correctly with WGM.
Within the business we have other tools which require higher versions of IE in order to function correctly. We thought a work around for this would be to use the embedded browser in Creo and WGM. We tested this OK on a few machines and rolled out this change recently to every client. We had immediate corporate meltdown with many CAD users experiencing serious problems, and were forced to hastely reverse this change.
I was planning to ask if anybody else had experienced issues with embedded browser.
11-Garnet
June 11, 2014
Has anyone found a solution to this? We are evaluating Firefox since all the IE security issues is forcing us to go to IE 11 (does not work with Windchill 10.1). We are getting the hangs on collecting related data.
David R. Martin II
Senior CAD Application Specialist
Amazon
We use Chrome without many problems as a stand alone browser with
Windchill 10.1. There was a problem in a recent update to Chrome that
broke the tab feature in Windchill 10.1, but other than that Chrome works
well. It is not a solution for the Creo embedded browser, however, We
still use IE for that.
Al Anderson
[solutions] - RE: Mozilla browser
Dave Martin
to:
solutions
06/11/2014 12:43 PM
Please respond to Dave Martin
Caterpillar: Confidential Green Retain Until: 07/11/2014
David R. Martin II
Amazon
Site Links: View post online View mailing list online Start new thread
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
Chrome is still working poorly for me after that update. Even on 10.2 M020.
[cid:image001.gif@01CF7046.C96AB930]
Stephen Vinyard
Business Development Manager/Solution Architect
David,
I do not have a solution for Mozilla; however, have been testing IE 11 on a variety of different 32 bit apps with some success.
Compatibility mode in IE 11 seems to be synonymous with 32 bit.
For IE 11, maybe try installing 32 bit JRE and automatically install the 32 bit Java browser plugins.
Then set the compatibility mode URL to your Windchill site.
-Marvin
Can you deploy Chrome 36 beta? That supposedly has the tab breakage issue resolved
If you go to M100 or newer there is a new option "browser_limit_to_ie9_mode". You can install IE10 or IE11 and they will run embedded as IE9.
I confirme With Chrome beta 36 and Chrome Canary (Dev 37) the tab problem in Windchill10.X is solved. There is a case open on PTC support :https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS172436&posno=3&q=chrome&nav=&source=Search.
I hope the official chrome version 36 will be deployed as soon as possible. Our users back to IE but with the navigation speed between us is huge.
I think it is supposed to be 5 weeks from now before it is released.
Brian Toussaint
Systems Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
