MS SQL Database Setup
  • August 5, 2011
  • 2010 views
I know that there is a Windchill command for Windchill 10 that will populate a SQL databse with the required data given that the DB has the correct tables and schemas. I had to use the command during the initial test deployment due to the installer not supporting a SQL cluster. I am now working on my production deployment and have missplaced the command somewhere in my notes. Does anyone know the command?
windchill wt.load.WindchillLoader
