New install of WC 10: Worked fine the first time, now nothing.
  • June 30, 2011
  • 8910 views
***It has now been confirmed this is an issue with WC 10.0 and is being looked into. It will go to R&D if a quick solution isn't found***
Hi guys,
Setup on a dev box. After the initial install everything worked fine. After the reboot all I get is the PTC spinning wheel after I login to the website. Any ideas?
  • I have DS running, Apache running, and Windchill running.
  • Server 2008 R2 8GB RAM
2011-06-30 09:34:41,937 INFO [main] wt.method.server.startup - Starting MethodServer
2011-06-30 09:34:41,941 INFO [main] wt.method.server.startup - JVM id: 4944
2011-06-30 09:34:41,941 INFO [main] wt.method.server.startup - JVM: Sun Microsystems Inc., Java HotSpot(TM) 64-Bit Server VM, 1.6.0_24 (19.1-b02), 64-bit
2011-06-30 09:34:41,941 INFO [main] wt.method.server.startup - OS: Windows Server 2008, amd64, 6.0
2011-06-30 09:34:41,943 INFO [main] wt.method.server.startup - Host: CORCEDEV02 (corcedev02.corp.jabil.org)
2011-06-30 09:34:41,944 INFO [main] wt.method.server.startup - Class path =
C:\ptc\Windchill_10.0\Windchill\codebase
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\archiveClientWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\archiveServerWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\archiveWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\CounterPartWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\dpimplWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\dpinfraWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\Gantt.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\ie3rdpartylibs.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\ieWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\install.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jmxcoreWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jviews-chart-all.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jviews-framework-all.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jviews-gantt-all.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\mylyn-integration.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\pdmlWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\prowtWeb.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\wc3rdpartylibs.jar
C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\wncWeb.jar
C:\ptc\Windchill_10.0\Windchill\lib\pdml.jar
C:\ptc\Windchill_10.0\Windchill\lib\servlet.jar
C:\ptc\Windchill_10.0\Windchill\lib\wnc.jar
C:\ptc\Windchill_10.0\Java\lib\tools.jar
C:\ptc\Windchill_10.0\Windchill\tomcat\bin\bootstrap.jar
C:\ptc\Windchill_10.0\Windchill\srclib\wnc\WtAsmAgent.jar
2011-06-30 09:34:41,945 INFO [main] wt.method.server.startup - Setting WTContext time zone to America/New_York; offset: -4.0
2011-06-30 09:34:41,970 INFO [main] wt.method.server.startup - Setting default time zone to GMT; offset: 0.0
2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.maxDbConnections= 15
2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.minDbConnections= 5
2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.dbConnectionsHardLimits= 25
2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.dbConnectionsSoftLimitWaitTime= 0
2011-06-30 09:34:50,838 INFO [main] wt.pom.properties - wt.pom.dbConnectionsWaitTime= 0
2011-06-30 09:34:50,838 INFO [main] wt.pom.properties - wt.pom.connectionCloserThreshold= 0
2011-06-30 09:34:50,838 INFO [main] wt.pom.properties - wt.pom.connectionCloserIdleTimeout= 0
2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.connectionMonitorSleepInterval= 10
2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.lostConnectionCodes=
2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.recoverableConnectionCodes= 28,1012,17002,17008
2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.freeConnectionImmediate= false
2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.maxIdleStatementCaches= 0
2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.jdbc.driver= com.microsoft.sqlserver.jdbc.SQLServerDriver
2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.url= jdbc:sqlserver:
2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.host= corcedev02.corp.jabil.org
2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.port= 1433
2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.service=
2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.database= wcsql1
2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbUser= wcsql1
2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbSchemaUser= wcsql1
2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesNameList=
2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesValueList=
2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.userDefinedFunctionsFileName= C:\ptc\Windchill_10.0\Windchill\db\userDefinedFunctions.xml
2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.rowPrefetchCount= 20
2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.statementCacheSize= 50
2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.cachedStatementReuseLimit= 50
2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.feedbackInterval= 500
2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.interruptInterval= 50
2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.cachedStatementRSLimit= -1
2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.navigateDepthThreshold= 4
2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.navigateDepthUnionLimit= 10
2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.queryDepthThreshold= 3
2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.queryDepthInClauseSizeLimit= 50
2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.lobChunkSize= 32000
2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.log.JDBCStatements= false
2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.log.fileJDBC= null
2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.log.filterJDBC= null
2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.chunk.defaultSize= 50
2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.objectReferenceQuerySize= 254
2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.objectReferenceQueryChunkSize= 500
2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.objectReferenceArrayTableEnabled= false
2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inflateHint= RULE
2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inflateSingleTableMode= true
2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.useBind= true
2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inClauseFixedSize= 5
2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inClauseSizeLimit= 1000
2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindLimit= 51
2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseUseBindOptimization= true
2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationThreshold=50
2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationTempTableUsePrimaryKey=true
2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationCardinality=-1
2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.cardinalityValueFixedSize= 100
2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.tempTableNumberPerThreshold= 5
2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeNumberOfThreshold=3
2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeThresholdValues=200,1000, 2000
2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.startupQueryLimit= -1
2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.queryLimit= -1
2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.queueInvokeTime= 600
2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.sessionCleanupTime= 1800
2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.threshold= -1
2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.insertChunkSize= 250
2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.fetchLimit= 15
2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.fetchSleepInterval= 1000
2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.closeSleepInterval= 600
2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.snapshotQueryLimit= 100000
2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.pagingSessionLimit= 5
2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.statementCache.summaryInterval= 2000
2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.enableNLSSort= false
2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.constantArrayTableLimit= 4000
2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.traceTiming.enable= true
2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.blobRead.handle620LV= false
2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.blobRead.handleOldLV= false
2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.blobRewrite.enabled= false
2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.selectForUpdateEnabled= false
2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.refreshCache.enabled= true
2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.refreshCache.summeryInterval= 0
2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.refreshCache.size= 300
2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.enableSQL99OuterjoinSyntax= true
2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.enableInListOptimizationWarning= false
2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.chunkThreshold=-1
2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.roleChunkSize=-1
2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.objectChunkSize=-1
2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.removeOids.objectChunkSize=-1
2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.batch.spec.tableExpressionThreshold=-1
2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.useTableType= true
2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.useColumnList= true
2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.classChunkSize= 2000
2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.chunkSize= 5000
2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.retry.enable= false
2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.closePreparedStatement.threshold=-1
2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.batch.insert.chunkSize= -1
2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.batch.update.chunkSize= 5000
2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.maxQueryRetryCount= 5
2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.oracle.blobInlineWriteThreshold= -1
2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.oracle.disableAlwaysSemiJoin= true
2011-06-30 09:34:50,855 INFO [main] wt.pom.properties - wt.pom.oracle.jdbcConnectionMemoryLimit= 48
2011-06-30 09:34:50,855 INFO [main] wt.pom.properties - wt.pom.oracle.nlssort.truncateLength= 600
2011-06-30 09:34:50,855 INFO [main] wt.pom.properties - wt.pom.emptyTableQueryClassChunkSize = 400
2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.size = 7
2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.queueSize = -1
2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.implicitEnabled=false
2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - Windchill DataStore: SQLServer
2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - JDBC Driver Version: major=3 minor=0
2011-06-30 09:34:51,894 INFO [main] wt.method.server.startup - MethodServer created - port 5003
2011-06-30 09:34:51,894 INFO [main] wt.method.server.startup - Starting services - class = wt.services.StandardServicesHandler
2011-06-30 09:35:25,239 INFO [main] wt.pom.properties - wt.pom.delete.triggerClassNames=
2011-06-30 09:36:20,379 INFO [main] wt.pom.properties - Connection: datastore=Microsoft SQL Server(10.50.1600) jdbcVersion=4.0 driver=Microsoft SQL Server JDBC Driver 3.0(3.0.1301.101) driverVersion=3.0
2011-06-30 09:36:24,110 ERROR [main] wt.audit.StandardAuditService - Project Audit Service: failed to set Administrator (ok if installation)
2011-06-30 09:36:28,790 ERROR [main] wt.access.agreement.StandardAgreementService - Agreement Service: failed to set Administrator (ok if installation)
2011-06-30 09:36:29,494 ERROR [main] wt.lifecycle - LifeCycle Service: failed to set Administrator (ok if installation)
2011-06-30 09:36:33,418 ERROR [main] wt.wrmf - wrmf.delivery.ShippingService: failed to set Administrator (ok if installation)
2011-06-30 09:36:33,617 ERROR [main] wt.workflow.forum.StandardForumService - StandardForumService : failed to set Administrator (ok if installation)
2011-06-30 09:36:33,681 ERROR [main] com.ptc.windchill.counterpart.StandardCounterPartService - Failed to set Administrator (ok if installation)
2011-06-30 09:36:35,088 INFO [com.ptc.core.logic.repository.server.impl.ChangeLocator$LoadLogicRepositoryTask] com.ptc.core.logic.repository.server.impl.ChangeLocator - Starting LoadLogicRepositoryTask.run()
2011-06-30 09:36:35,186 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Started initializeXML()
2011-06-30 09:36:35,474 INFO [com.ptc.core.logic.repository.server.impl.ChangeLocator$LoadLogicRepositoryTask] com.ptc.core.logic.repository.server.impl.ChangeLocator - Finished LoadLogicRepositoryTask.run()
2011-06-30 09:36:37,169 ERROR [main] com.ptc.core.lwc.server.cache.db.TypeDefinitionDBService - Type Definition Service: failed to set Administrator (ok if installation)
2011-06-30 09:36:37,735 ERROR [main] wt.dataops.objectcol.StandardCollectionService - dataops.objectcol.CollectionService: failed to set Administrator (ok if installation)
2011-06-30 09:37:05,130 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Finished initializeXML()
2011-06-30 09:37:13,089 ERROR [main] wt.vc.StandardVersionControlService - StandardVersionControlService: failed to set Administrator (ok if installation)
2011-06-30 09:37:14,313 INFO [main] wt.method.server.startup.services - All managers started.
2011-06-30 09:37:14,314 INFO [main] wt.method.server.startup - StandardManagerService started
2011-06-30 09:37:14,314 INFO [main] wt.method.server.startup - Services started.
2011-06-30 09:37:14,473 INFO [main] wt.method.server.startup - MethodServer registered with ServerManager
2011-06-30 09:37:14,474 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap
2011-06-30 09:37:14,501 INFO [main] wt.method.server.startup - Creating wt.method.WTAdapter
2011-06-30 09:37:14,545 INFO [main] wt.method.server.startup - Creating com.ptc.core.adapter.server.impl.SimpleTaskDispatcher
2011-06-30 09:37:14,687 INFO [main] wt.method.server.startup - Creating wt.method.ClusterMonitor
2011-06-30 09:37:14,709 INFO [main] wt.method.server.startup - Creating wt.method.jmx.Startup
2011-06-30 09:37:20,715 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.methodServer.info - JVMName=4944@CORCEDEV02,
StartTime=1309440878535,
MaxHeapBytes=2433875968,
ServiceName=MethodServer,
JVMArguments=[-XX:+UseCompressedOops,
-javaagent:C:\ptc\Windchill_10.0\Windchill\srclib\wnc\WtAsmAgent.jar,
-Xverify:none,
-Xrs,
-Djava.endorsed.dirs=C:\ptc\Windchill_10.0\Windchill\lib\endorsed,
-Djava.awt.headless=true,
-Dwt.manager.serviceName=MethodServer,
-Dwt.logs.dir=C:\ptc\Windchill_10.0\Windchill\logs,
-Dcom.sun.management.jmxremote,
-Djmx.remote.protocol.provider.pkgs=wt.jmx.remote.protocol,
-Dlog4j.configuration=WEB-INF/log4jMethodServer.properties,
-Dwt.tomcat.embeddedMode.enable=true,
-Xms2422m,
-Xmx2422m,
-XX:PermSize=184m,
-XX:MaxPermSize=400m,
-Dsun.rmi.dgc.client.gcInterval=3600000,
-Dsun.rmi.dgc.server.gcInterval=3600000,
-Xloggc:C:\ptc\Windchill_10.0\Windchill\logs\MethodServer-110630093437415-2-GC.log,
-XX:+PrintGCDetails,
-XX:+PrintGCDateStamps],
AvailableProcessors=2
2011-06-30 09:37:21,589 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=140087536, NonHeapMemoryUsage=106958464, Uptime=163054, ProcessCpuTime=47703125000, JITCTime=24291, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[672,534], GCCount=[2,4], Classes=11371, Threads=36, TotalStartedThreadCount=43, PermGenPercentCollUsage=24.219070434570312, PermGenPercentUsage=24.219070434570312
2011-06-30 09:37:21,613 ERROR [main] wt.method.jmx.LogTableCleaner - Failed to set Administrator (OK if installation)
2011-06-30 09:37:21,613 INFO [main] wt.method.server.startup - Creating wt.phonehome.queue.PhoneHomeQueueScheduler
2011-06-30 09:37:21,929 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap$WaitUntilStarted
2011-06-30 09:37:40,216 INFO [Tomcat main] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization started
2011-06-30 09:38:00,828 INFO [Tomcat main] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization completed in 20610 ms
2011-06-30 09:38:00,980 INFO [Tomcat main] com.ptc.tomcat.embedded.Bootstrap - Embedded Tomcat ready; catalina.base=C:\ptc\Windchill_10.0\Windchill\tomcat\instances\instance-8010
2011-06-30 09:38:00,984 INFO [main] wt.method.server.startup - MethodServer ready (in 202.449 secs).
2011-06-30 09:41:33,536 ERROR [TP-Processor7] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill] - Session event listener threw exception
wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
Nested exception is: java.lang.reflect.InvocationTargetException; nested exception is:
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.ptc.core.appsec.FoundationHolder.getPrincipal(FoundationHolder.java:263)
at com.ptc.core.appsec.FoundationHolder.getPrincipalName(FoundationHolder.java:188)
at com.ptc.core.appsec.CSRFNonce.createMessage(CSRFNonce.java:411)
at com.ptc.core.appsec.CSRFNonce.initializeMac(CSRFNonce.java:306)
at com.ptc.core.appsec.CSRFNonce.initialize(CSRFNonce.java:153)
at com.ptc.core.appsec.CSRFNonce.newCSRFNonce(CSRFNonce.java:122)
at com.ptc.core.appsec.CSRFProtector.addNonce(CSRFProtector.java:285)
at com.ptc.core.appsec.CSRFSessionListener.sessionCreated(CSRFSessionListener.java:37)
at org.apache.catalina.session.StandardSession.tellNew(StandardSession.java:381)
at org.apache.catalina.session.StandardSession.setId(StandardSession.java:353)
at org.apache.catalina.session.ManagerBase.createSession(ManagerBase.java:881)
at org.apache.catalina.session.StandardManager.createSession(StandardManager.java:291)
at org.apache.catalina.connector.Request.doGetSession(Request.java:2411)
at org.apache.catalina.connector.Request.getSession(Request.java:2120)
at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:833)
at wt.servlet.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:130)
at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:216)
at org.apache.catalina.core.ApplicationHttpRequest.getSession(ApplicationHttpRequest.java:547)
at org.apache.catalina.core.ApplicationHttpRequest.getSession(ApplicationHttpRequest.java:493)
at org.apache.jasper.runtime.PageContextImpl._initialize(PageContextImpl.java:146)
at org.apache.jasper.runtime.PageContextImpl.initialize(PageContextImpl.java:124)
at org.apache.jasper.runtime.JspFactoryImpl.internalGetPageContext(JspFactoryImpl.java:107)
at org.apache.jasper.runtime.JspFactoryImpl.getPageContext(JspFactoryImpl.java:63)
at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:84)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:386)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:238)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:250)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1063)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:801)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:61)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at wt.httpgw.filter.TrustedAuthFilter.doFilter(TrustedAuthFilter.java:130)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:231)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:325)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1591)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:811)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:740)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:933)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Thread.java:662)
Caused by: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
at wt.session.StandardSessionManager.getAuthenticatedUser(StandardSessionManager.java:426)
at wt.session.StandardSessionManager.getPrincipal(StandardSessionManager.java:178)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:249)
at $Proxy16.getPrincipal(Unknown Source)
at wt.session.SessionHelper.getPrincipal(SessionHelper.java:157)
... 80 more
2011-06-30 09:41:33,786 ERROR [TP-Processor7] com.ptc.windchill.enterprise.navigation - Can't find WTUser on Session
at com.ptc.windchill.enterprise.navigation.renderers.HeaderUtil.getUserInfo(HeaderUtil.java:121)
at com.ptc.windchill.enterprise.navigation.renderers.HeaderUtil.getWelcomeMessage(HeaderUtil.java:104)
at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:159)
2011-06-30 09:41:34,001 ERROR [TP-Processor7] com.ptc.jca.navigation - problem getting the main navigation action model
at wt.session.StandardSessionManager.getPrincipalReference(StandardSessionManager.java:200)
at $Proxy16.getPrincipalReference(Unknown Source)
at com.ptc.netmarkets.util.misc.StandardNmActionService.createValidationCriteria(StandardNmActionService.java:3042)
at com.ptc.netmarkets.util.misc.StandardNmActionService.getValidatedActionModel(StandardNmActionService.java:2798)
at com.ptc.netmarkets.util.misc.StandardNmActionService.getActionModel(StandardNmActionService.java:561)
at $Proxy24.getActionModel(Unknown Source)
at com.ptc.windchill.enterprise.navigation.delegates.DefaultNavigationListDelegate.getActionModel(DefaultNavigationListDelegate.java:209)
at com.ptc.windchill.enterprise.navigation.delegates.DefaultNavigationListDelegate.getJSONForShell(DefaultNavigationListDelegate.java:440)
at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:162)
2011-06-30 09:41:34,096 ERROR [TP-Processor7] com.ptc.windchill.uwgm.common.container.ContainerUtilities - ContainerUtilities.getOrgContainerOfSessionUser :: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
2011-06-30 09:41:34,199 WARN [TP-Processor7] com.ptc.windchill.uwgm.common.prefs.UwgmPreferences - UwgmPreferencesImpl.<init> :: Cannot obtain a principal from Session
at com.ptc.windchill.uwgm.common.prefs.UwgmPreferencesImpl.<init>(UwgmPreferencesImpl.java:66)
at com.ptc.windchill.uwgm.common.prefs.UwgmPrefFactory.getPreferences(UwgmPrefFactory.java:34)
at com.ptc.core.htmlcomp.util.preference.PreferenceContext.createPreferenceContext(PreferenceContext.java:143)
at com.ptc.core.htmlcomp.util.preference.PreferenceContext.newPreferenceContext(PreferenceContext.java:89)
at com.ptc.core.htmlcomp.util.preference.PreferenceContext.newPreferenceContext(PreferenceContext.java:114)
at com.ptc.core.htmlcomp.util.DateFormatUtilities.getLocalTimeZone(DateFormatUtilities.java:297)
at com.ptc.core.htmlcomp.util.DateFormatUtilities.createTimeZoneDisplayNamesJSON(DateFormatUtilities.java:435)
at com.ptc.core.htmlcomp.util.DateFormatUtilities.printDateFormatJS(DateFormatUtilities.java:127)
at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:214)
2011-06-30 09:41:36,367 ERROR [TP-Processor7] com.ptc.core.components.jsp.JspUtils - wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
at com.ptc.core.appsec.CSRFProtector.getNonce(CSRFProtector.java:136)
at com.ptc.core.appsec.CSRFProtector.getNonce(CSRFProtector.java:115)
at com.ptc.core.appsec.CSRFProtector.getNonce(CSRFProtector.java:93)
at com.ptc.core.components.tags.components.RenderMainFormTag.printForm(RenderMainFormTag.java:130)
at com.ptc.core.components.tags.components.RenderMainFormTag.doTag(RenderMainFormTag.java:74)
at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspx_meth_jca_005frenderMainForm_005f0(clearDynamicAttributes_jsp.java:1441)
at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspx_meth_c_005fif_005f9(clearDynamicAttributes_jsp.java:1413)
at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspx_meth_c_005fif_005f8(clearDynamicAttributes_jsp.java:1350)
at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspService(clearDynamicAttributes_jsp.java:298)
at com.ptc.core.components.filter.JCAFilter.doFilter(JCAFilter.java:96)
... 60 more
2011-06-30 09:41:36,376 ERROR [TP-Processor7] wt.method.MethodContextMonitor.contexts.servletRequest - 2011-06-30 13:41:35.779 +0000, 1br44s1;gpjrari4;4944;pot4xk;82, -, -, 1br44s1;gpjrari4;4944;pot4xk;81, wcadmin, 172.27.8.49, -, -, , 0, 0, 0.001332012, 0.21875, 0.595372596
javax.servlet.ServletException: javax.servlet.jsp.JspException: Unable to print mainform
at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:861)
at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:794)
at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspService(clearDynamicAttributes_jsp.java:759)
Caused by: wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
at com.ptc.core.appsec.FoundationHolder.getPrincipalName(FoundationHolder.java:191)
... 40 more
Caused by: wt.util.WTException: java.lang.reflect.InvocationTargetException
at com.ptc.core.appsec.FoundationHolder.getPrincipal(FoundationHolder.java:265)
... 54 more
Caused by: java.lang.reflect.InvocationTargetException
... 55 more
... 60 more
2011-06-30 09:41:36,383 ERROR [TP-Processor7] wt.servlet.ServletRequestMonitor.request wcadmin - 2011-06-30 13:41:35.778 +0000, 1br44s1;gpjrari4;4944;pot4xk;81, wcadmin, 172.27.8.49, /Windchill/netmarkets/jsp/util/clearDynamicAttributes.jsp, dynamicFlush=true, POST, 302, 0.234375, 0.602721575
... 60 more
2011-06-30 09:41:36,387 ERROR [TP-Processor7] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill].[jsp] - Servlet.service() for servlet jsp threw exception
2011-06-30 09:47:18,131 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.001539861, CompletedContexts=22, ErrorCount=1, RedirectCount=0, ContextSecondsAverage=2.4308329945000002, ContextSecondsMax=46.233862404, ContextCpuSecondsAverage=0.8053977272727273, ContextUserSecondsAverage=0.6065340909090909, ContextJDBCConnWaitSecondsAverage=9.724445454545455E-5, ActiveContextsAverage=0.6899436152912244, ActiveContextsMax=4, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=1.0454545454545454, PercentageOfContextTimeInJDBCCalls=1.8956242483986976, PercentageOfContextTimeInJDBCConnWait=0.004000458063778126, PercentageOfContextTimeInJNDICalls=0.8032379808820455
2011-06-30 09:47:18,233 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.053, CompletedContexts=20, ErrorCount=0, ContextSecondsAverage=0.0313805525, ContextSecondsMax=0.249271905, ContextCpuSecondsAverage=0.00859375, ContextUserSecondsAverage=0.0046875, ActiveContextsAverage=0.0010467836041149698, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
2011-06-30 09:47:18,292 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=659.502, TotalContexts=52, ErrorCount=0, ContextsPerSecond=0.07884737271456342, AverageContextSeconds=0.015888880076923077, LongestContextSeconds=0.233806811, AverageActiveContexts=0.0012524956967530046, MaxActiveContexts=1
2011-06-30 09:47:18,292 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=733.311, TotalContexts=30, ErrorCount=0, ContextsPerSecond=0.040910336814802994, AverageContextSeconds=0.024433021533333335, LongestContextSeconds=0.183655744, AverageActiveContexts=9.984267261775699E-4, MaxActiveContexts=1
2011-06-30 09:47:22,339 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=154370744, NonHeapMemoryUsage=141988648, Uptime=763803, ProcessCpuTime=86109375000, JITCTime=42049, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[1314,761], GCCount=[3,7], Classes=15447, Threads=48, TotalStartedThreadCount=131, PermGenPercentCollUsage=31.911172866821293, PermGenPercentUsage=31.911172866821293
2011-06-30 09:47:36,066 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001651048, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
2011-06-30 09:47:36,720 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001885715, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
2011-06-30 09:47:39,588 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=0.610259800292909, ActiveSessionsMax=1, ActiveSessionsStart=0, ActiveSessionsEnd=1, ElapsedSeconds=600.001103772, SessionsCreated=1, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
2011-06-30 09:47:40,252 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.001945219, CompletedRequests=4, ErrorCount=0, RequestSecondsAverage=0.8849283215, RequestSecondsMax=2.518869018, RequestCpuSecondsAverage=0.25390625, RequestUserSecondsAverage=0.17578125, ActiveRequestsAverage=0.005943699370338424, ActiveRequestsMax=1, ActiveRequestsStart=0, ActiveRequestsEnd=0
2011-06-30 09:57:18,157 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.002929143, CompletedContexts=9, ErrorCount=0, RedirectCount=0, ContextSecondsAverage=0.01028737188888889, ContextSecondsMax=0.016413818, ContextCpuSecondsAverage=0.008680555555555556, ContextUserSecondsAverage=0.006944444444444444, ContextJDBCConnWaitSecondsAverage=7.667E-6, ActiveContextsAverage=1.0001543098250074, ActiveContextsMax=2, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=0.0, PercentageOfContextTimeInJDBCCalls=0.0, PercentageOfContextTimeInJDBCConnWait=0.07452826711048445, PercentageOfContextTimeInJNDICalls=0.0
2011-06-30 09:57:18,257 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.024, CompletedContexts=0, ErrorCount=0, ContextSecondsAverage=NaN, ContextSecondsMax=0.0, ContextCpuSecondsAverage=NaN, ContextUserSecondsAverage=NaN, ActiveContextsAverage=0.0, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
2011-06-30 09:57:18,318 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=600.026, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
2011-06-30 09:57:18,318 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=600.026, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
2011-06-30 09:57:23,290 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=128092576, NonHeapMemoryUsage=141580296, Uptime=1364754, ProcessCpuTime=87796875000, JITCTime=42157, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[2233,766], GCCount=[4,8], Classes=15450, Threads=48, TotalStartedThreadCount=201, PermGenPercentCollUsage=31.80964851379395, PermGenPercentUsage=31.80964851379395
2011-06-30 09:57:36,091 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001927619, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
2011-06-30 09:57:36,745 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001923708, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
2011-06-30 09:57:39,613 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=1.0, ActiveSessionsMax=1, ActiveSessionsStart=1, ActiveSessionsEnd=1, ElapsedSeconds=600.001905829, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
2011-06-30 09:57:40,276 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.000997333, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
2011-06-30 10:07:18,182 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.001928178, CompletedContexts=8, ErrorCount=0, RedirectCount=0, ContextSecondsAverage=0.010269461375, ContextSecondsMax=0.015265069, ContextCpuSecondsAverage=0.0
Hi Andrew,
Some errors that I saw
1. Failed to Set Administrator
2.wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
3. getPrincipal Dailed
It seems that the either the Base data is not loaded properly or Windchill DS or Apache service is not started.
Make sure you have set WindchillDS and Apache(if running as a service) service set to automatic startup in the services control panel.
Rhan
I understand what you are saying.
1. How do I set Administrator, wcadmin is working fine.
2. Apache and DS is running as a service.
***Solution***
Re-install. Make sure you are using all of the most recent packages.
Close topic please.
