Not able to delete a folder from Vault Configuration.
  • June 5, 2011
  • 2083 views
Am trying to delete a folder (and eventually a replica site itself) from Vault Configuration window. On deleting a replica folder (under Replica Folders under a replica site), the system gives me this notice:
Can not remove Replica folder, it contains Cached items.
What is the way out to delete the replica folder?
Prabhakaran V.
You cannot delete a folder that has items that have not been sync'd back to the master site (ie there are cached items).
You will need to force a SYNC of all data back to the master site:
From a Windchill shell run jconsole and connect to the main methodserver process shown in the listing window.
Select the MBean Tab and then open the com.ptc / monitors / CacheVaultSynchronizer / Operations and press the button for sysForceSync in the RHS pane.
If this complete successfully you will be able to delete the folder
Rgds
Gary
