Notification if Indexing or Publishing is down?
We have PDMLink 9.1 and are having issues with publishing and indexing going down. We have a separate workstation that is used to publish our CADD files andthe workstationhas Fast InStream for indexing. The issue is that we do not know when the publisher or indexer go down. Our main concern is the indexer. If files are not being indexed, then older rev files will be found from a global search. Then someone could check out an older rev file and make changes, not knowing there is a newer rev out there. We have stopped using our global search for now. It would be nice to get a notification if the publisher or indexer go down. Otherwise, it could be a week or two later and then we have to reindex the whole vault.
