Order of Custom Attributes on Change Request
  • December 1, 2010
  • 564 views
Hi all.
I am adding several custom attributes to a Change Request. When I add them they automatically show up in alphabetically order. I need to be able to add them in a certain order so that they show up on the form in a certain order. Any thoughts?
Brian
If you only want to get them in a determined order, you may follow steps described in Windchill Customizer's Guide p13-92 to 13-96 ("Attribute tables").
Indeed, you will hae to delete the line reference by "ALL_SOFT_SCHEMA_ATTRIBUTES" and add a line :
<jca:describeproperty id="[your" soft=" type]&quot;="/>
for each soft type you want to be displayed.
Please ask if you need further infos, but I'm not a "professional" of Windchill.I looked further attribute display because i'm looking for a way to group them.
Sincerely,
Thibault Magné
