Painful remove from workspace suggestions
I have a question regarding removing items from a workspace. We have several workspaces which are a mixture of conceptual designs in progress and other designs which have been checked in now. I wish to clean up the workspace and remove many/most of the parts except the ones which are still in progress.
The issue is if I select 100 parts and try to remove from the workspace, the entire operation fails and nothing is removed if only 1 of the parts is needed for somethign which will remain in the workspace. Is there a setting which will allow it to remove everything possible, and only leave what cannot be removed due to links instead of everything failing? 90% of the WS is checked in with no modifications, but it is VERY painful and slow to manually figure out which parts are still required and delete only the rest.
Thanks!
