PartsLink attributes displayed in Scientific Notation
  • August 5, 2011
  • 824 views
I've recently classified a number of parts in PartsLink, and all of the values for attributes of type "real" are being displayed in the search results in scientific notation. For example, if the diameter of a screw is 0.125 in, it displays it as 1.25E-1 in. This only occurs in the PartsLink/Classification Search results, and seemingly only for the values less than one. I'm running Windchill 9.1, M060.
This problem occurs regardless of whether I import the attributes from a spreadsheet or enter them manually in PDMLink. I've tried modifying the precision settings in Counterpart, but have seen no change. When I'm looking at the actual page for a part, the values are listed correctly. It's only in the PartsLink search results that they are displayed incorrectly.
Thanks in advance,
Joe
Hi Joe,
We had a similar issue and PTC provided us a temp patch for this in 9.1 M040 (9.1-M040_TP32). This patch will fix the problem.
-Nirmesh
