PDMLink 9.1 not collecting associated drawings
  • November 9, 2010
  • 3 replies
  • 593 views
using advanced add to workspace then selecting the add drawings icon does not collect any drawings for assembly components, I also tested on a single family table object and didn't collect the drawing, has anyone seen this, this seems like intended functionality?
Hi Kevin.
We're running 9.1 m050. I creaetd a new WS, selected Add and searched for an assembly and it's drw. I selected both then clicked the Advanced tab. The asm includes Required dependants. I selected a couple components then clicked the Drawing icon to collect the related drws and the drws were added to the Add to Workspace display.
Best Regards, Jim
kjohns1011-VisitorAuthor
is your configuration set to "Latest", if yes set to As Stored and verify same results
Yes Kevin, config was 'Latest'. I repeated per your request and changed the config to 'As Stored'. With this configuration the related drws of the assemblycomponents could not be collected.
Regards, Jim
