Problem while replicating folders
  • April 12, 2013
  • 1558 views
I am getting the following error whil trying to replicate folders from the master site to the replica site.
The broadcast is working fine. Any help ??
WARN : wt.fv.replica - Could not get host description for skd1-plm-fileserver.sona.com from cache.
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: WARN : wt.fv.replica - This could mean that the configuration information is out of date, or that the master site does not have the correct host/site name
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: TRACE : wt.fv.replica - currKey = http://plm.sona.com/Windchill/servlet/WindchillGW104323163
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: ERROR : wt.fv.replica - Vault 104323163 from site http://plm.sona.com/Windchill/servlet/WindchillGW not found in findFolderToSaveFile
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: ERROR : wt.fv.replica - Configuration Update Needed from http://plm.sona.com/Windchill/servlet/WindchillGW
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: ERROR : wt.fv.replica - This can be accomplished by stopping and starting the replica method server.
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: ERROR : wt.fv.replica - ERROR while storing content
Wed 4/10/13 15:23:03: RMI TCP Connection(32)-172.16.2.34: wt.fv.FvFileCanNotBeStored
Best answer by ptc-4767033
the host names for all the servers are case sensitive and have to be written in CAPS in order for the broadcast to work fine.
ptc-47670331-VisitorAuthorAnswer
