Process Monitor - does anyone use it??
  • January 19, 2011
  • 2 replies
  • 2419 views
I use Process manager but should I also use the Process Monitor and if so is it helpful?
I can't find about the Process Monitor it in HELP, but I wish to use it (I think!!)
Use Process Monitor when you want a user to be able to view the overall wf process. Process Monitor only shows you an image file. It is helpful for a user who does not hace access to Process Manager, or who wants to open something lightweight. Add the image from the Workflow template.
Sarah1-VisitorAuthor
OK - I sort of knew that, what I wanted to know has anyone actually added an image in? and/ or do you use a process with one attached??
Is it helpful?
