Publish Monitor - Home/Utilities vs. Org/Utilities
  • May 11, 2010
  • 7128 views
The publish monitor from the Org/Utilities screen shows the number, name, version, context, and user, but the publish monitor in the Home/Utilities tab does not. We need that information (name, version, etc) to show up in the publish monitor on the Home/Utilities tab? Any suggestions?
Which Version of Windchill are you using. I checked this on 9.1 M050 and it works fine
Ninjette1-VisitorAuthor
9.0 M030. It shows all of this information if I am logged in as wcadmin, but if I'm logged in with an org admin account or a regular user account it doesn't. I need my users (or a subset of them) to be able to see the values in those columns on their Home\Utilities screen. Do you see it if you're logged in with a regular user account?
The Home Utlities--> link shows only the object's info checked in by that particular user which were sent for publishing. Infact, whatever changes like preferences which are available under Home--> Utilities will apply only to that particular user. Even an Org Admin will not able to see the object info in Publish monitor when he accesses the same from Home-->Utilities.But, if he wants to see the info for ALL objects (under that Org) which were sent for publishing he can view the same by launching the Publish Monitor from Org--> Utilities. Similarly, a Product Manager can see ALL product objects details by launching from Product--> Utilities.
