Query Attribute of Object Attached to Promotion Request
  • November 21, 2013
  • 13 replies
  • 5053 views
I am looking for a way to query a particular attributes value of an object attached to a promotion request. We are using Windchill 10.0 M040 and will be updating to 10.1 M030 this weekend.
For example, we have a custom boolean attribute (CertificationControlled)attached to the DefaultEPMDocument object type, and we need to know when objects with that value set to 'Yes' are submitted for promotion within a Promotion Request. I can loop through the objects attached to the promotion request object, but I am not sure how to get the attribute value and check to see if it is true or not. Any help will be appreciated.
Benjamin Wilcox – IntelliServ<sup>™</sup>
PPM & PDM Administrator
IntelliServ provides broadband networking and along-string
evaluation services for high-definition downhole and sub-surface operations
> Get the Facts.
bwilcox1-VisitorAuthor
I found an error in my code -- had forgotten a close }. Now, though, I get a different error:
D:\ptc\Windchill_10.0\Windchill\temp\WfExpression493019533.java:48: cannot find symbol
Syntax check complete.
Any ideas?
> Get the Facts.
November 22, 2013
Add complet class path for Persistable and local
com.ptc.core.lwc.server.LWCNormalizedObject obj = new com.ptc.core.lwc.server.LWCNormalizedObject((wt.fc.Persistable) myObject, null, java.util.Locale.ENGLISH, null);
Shreyas
Thank you. That is what I needed. My code is working very nicely, now. Thank you to all for your help!
> Get the Facts.
