Query Builder_Retrieving Comments field in a Variable
  • April 11, 2013
  • 984 views
HI,
I am working on query builder in Windchill 10.1 . I need to retrieve the "Comments" variable as a column in the Report which will be generated.
The object which is routed for approval is : Change Request object. I need to retrive the Approver's comments and display it in the Report column.
Any help will be highly appreciated.
Thanks and regards,
Shweta Joshi
Hi Shweta,
You can have to use this Join :- WorkItem primary business object WTChange order
In select tab of querybuilde, you can choose Workitem-->Context-->Task Comments.
