re-linking drawings to orphaned parts...
  • August 29, 2012
  • 558 views
I'm new with Windchil, and I hope this is the correct forum. I have inherited a situation as follows...
We havepart A.prt with drawing A.drw all fine and dandy in Winchill 9.1. Then "someone" created a new version of A.prt, called B.prt WITHOUT carrying the drawing along. So I am wondering if there is a simple way to RELINK the A.drw to the B.prt within the context of Windchill.
I think one option would be to export A.prt, A.drw and B.prt. Then do the typical Pro/E relink; open B.prt, rename it in session to A.prt, open A.drw then rename both to B.prt/drw and save. Then I should be able to import B.prt and B.drw back into Windchill.
thanks in advance...
(and apologies if this isn't the correct foum... what would be the correct one?)
This procedure requires the hidden Preference - Save As Replace With Workspace Content to be set as described in TPI 147439.
Procedure
* Check out drawing to an empty Workspace (Part A comes along too)
o The Workspace cannot contain Part B
* In the Workspace select the Part A and do File > Save As
o Change File name and Number to Part B and leave its option as "New" (default)
o Hit Next to get to the Update Parents window, select the drawing and pick the "Replace" option button
o Hit the Finish button
* The Event Manager opens > Select the "Resolve Conflicts" icon (this is where that hidden preference comes into play)
o Leave the Retry Option as "Check Out and Overwrite" (default) > Retry
o In Workspace the drawing and Part B appear as "Checked Out" and "Modified"
* Select Part B > Cancel Checkout
* At this point you can open the drawing in Pro/E and verify that everything's OK
* Select the drawing > Check In
Mike Foster
ATK
