6-Contributor
June 30, 2025
Rename CAD document number Automatic
"We need to automatically update the CAD document number in the Windchill database based on the file name.
Here are the errors that I faced
Fadel
23-Emerald II
June 30, 2025
can you elaborate, do you need this for existing documents ? if yes tale a look at https://www.ptc.com/en/support/article/CS145098
Buiꓘa
avillanueva
23-Emerald II
June 30, 2025
There are preference settings when CAD data is checked in to have number align with filename. If you are trying to clean up the current system to make them align, what @Fadel posted is the right path. You will have to create your own script to do this. Not a difficult program to read in from a text file or something like that to process all the changes.
Community Moderator
July 4, 2025
Hello @PC_10366408,
It looks like you have some responses from our community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
