Rename number option greyed out - modify identity?
  • April 23, 2012
  • 6 replies
  • 9420 views
I am a mechanical engineer and working with the system administrator to implement Windchill 10 at our company.
Once a part is checked-in, we would like the ability to rename the "number" in the system. We often start a new product with names like "block" and "screw". Once a product moves into to the quote stage, individual parts are given company part numbers. Is seems that once a part is in Whindchill we can not rename the "name" of the part. This option is greyed out. The work around that we are currently using is to do a save-as.
From reading the help files it seems that we need to grant the Modify Identity Permission, but out sys admin does not have this option.
Any help would be greatly apreciated!
Best answer by ptc-2734082
We discovered the solution to the problem. It required editing a .XML and loading it into windchill. Apparently the default setting prevents allowing this parameter from being edited. We needed to remove the setting in the .XML file. Why PTC does this...I have no idea.
It should be there...but may depend on how your system is setup and where your access policies are defined. Ours are setup in the Product level, but they could also be pushed down from the organization or site level. Are you at the product -> Utilities -> Policy Administration. You can drill down from the organizations and view the policies from there. Depending on your access level, you can also see if they are inherited from the orgainization level. hope that helps.
Max,
Maybe this is what I am looking for? Do you think you could provide additional information. All I would like to do is modify the name of a part.
It is difficult to help out specifically because there are many different ways to control access policies. The method i pointed out is where you need to go (utilities -> policy administration). Areas to understand are how complicated is your structure, where are you wishing to grant this permission, and what object types are you are wishing to modify (WTParts, EPMDocuments, etc)? If you have multiple organizations, products, or libraries, think before you make a change and plan for the best context. the general steps are to: locate the context where you wish to grant the permission, identify the role of the person who should be granted permission (designer, engineer, etc), find the associated entry in the list of permission rules, and finally edit it to give modify identity permissions. Also, if you are planning to create more products/libraries in the near future, it would be a good idea to update the product/library template with the change if you are making the change in that context.
Sorry to answer your question with more questions and open ends, but it can vary widely between installations and the access policies can get quite complex. In my system, the access policy for modify identity is granted within the specific product/library context. hope that helps.
