Renaming in WindChill Cabinets.
  • August 7, 2013
  • 1058 views
Greetings,
We have an situations, where there is two names for the same file.. We have a two naming system since we have a back up system. We have accidentally named a simple single part file two different names. I am working in Windchill to change the name, but continue to get told the name is not unique. This file is already checked in and we are doing the name change from windchill cabinets. We even tried to change it to a goofy unique name to eliminate the message, but it still continues to fail. The error message is "file name is not unique."
All Suggestions are welcomed.. what are we doing wrong?
Thanks in advance,
Diane
23-Emerald II
August 29, 2013
Does the issue go away if you also change filename and number?
