Replace a Pro/E assembly component using Workspace Save As
Is there a way in Intralink 9.1 with Pro/E to replace an assembly component in Workspace without having to open the assembly in Pro/E and manually replace it?
In Intralink 3.4 this was easily done as follows:
1. Check out assembly to an empty Workspace
2. Duplicate the part to be replaced to the name of the replacement part and set Update Parent to true
3. The replacement part is marked both "New" and "Same Name Exists"
4. Update the replacement part and override the conflict.
5. The assembly now contains the replacement and can be checked in
As long as the replacement component is derived from the original the assembly constraints still work. This is a huge time saver if you want to replace hundreds of screws in an assembly with a similar screw of a different part number.
I know that using the "Save As" function in 9.1 I can replace an existing component in an assembly with a new one but what I want to do is replace an existing component in the assembly with a different one that isn't new.
In Intralink 9.1 step 2 doesn't work, I cannot do a Workspace Save As to the same name as an existing Commonspace object.
Mike Foster
ATK
Mike Foster
ATK
