ResourceBuild failing for rbinfo files in wtCustom in Windchill 10.1
  • June 7, 2013
  • 3250 views
we have customized few rbinfo files like
com.ptc.core.ui.navigationRB
com.ptc.windchill.pdmlink.change.client.changeRB
by adding in /wtCustom folder in windchill 9. We are upgrading to windchill 10.1. I tried to do ResourceBuild from wtCustom folder it failed by giving error as "resource info not found". I understood that the corresponding rbinfo file in src package is missing in Windchill 10.1 and respective Java resource files are present. How can I move ahead with this.Do I need to copy the java resource files in wtCustom and edit it and then do a build ?
Use the enumCustomize from Windchill shell and add the new value in the wtCustom,Change2 folder and rebuild the jar.
ok .. but how can i customize WTListResourceBundle type resource file for eg. com.ptc.core.ui.navigationRB available as java file in windchill 10.1 ?
the problem is solved ..
Reference to PTC Document :
  • 10.0 implementations of String resources implement java.util.ListResourceBundle
  • See windchill/src/wt/util/resource/resourceCustomize.rbInfo file for more details
  • To automatically convert resources of type wt.tools.resource.StringResourceInfo to Java based resources, use
ant -f bin\tools.xml custom_convert
  • The Ant target is available starting at 10.0 M030
  • The original *.rbInfo file is renamed to *.orig, a new file is created with extension *.converted
  • The entries from the *.converted file are appended to file windchill/src/wt/util/resource/resourceCustomize.rbInfo
  • The converted resource can now be compiled with command
ant -f bin/tools.xml bundle_custom -Dbundle.recurse=true
  • The compiled entries are added to wt.util.resource.resourceCustomize.class file
