8-Gravel
Mar 11, 2025 10:31 AM UTC
Rules for attributes mandatory when upgrade state
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.9
Please, we use several states (design, prototype, and production) and we use partslink (parts with classification attributes).
How is it possible to ensure, when we upgrade from prototype to production, that we have a check that all classifications attributes are filed.
If it's not the case, stop the upgrade.
    Fadel
    FadelAnswer
    23-Emerald II
    Mar 11, 2025 1:52 PM UTC
    you need some kind of business rules to do the validation on the attributes , see https://www.ptc.com/en/support/article/CS301629 , https://www.ptc.com/en/support/article/CS156636, https://www.ptc.com/en/support/article/CS361541
    Buiꓘa
    avillanueva
    23-Emerald II
    Mar 11, 2025 11:23 AM UTC
    Did you mean to use the word "upgrade"? That typically means Windchill version change. I think what you mean is promotion or change in lifecycle state. If the latter, you can build these checks into a promotion request workflow or a listener.  Attributes can be made mandatory such that at any point, they are required to be filled out. I see that you might want it non-mandatory early on but as it progresses, flip that. I do not think that can be done by lifecycle state which is why it needs to be built into your promotion workflows. This can be done in change notice workflow is that is your process to move states as well.
    ZANET8-GravelAuthor
    8-Gravel
    Mar 11, 2025 12:12 PM UTC
    You're right Avillanueva, I mean promotion in lifecycle state. I'm going to look for informations about promotion workflows.
    You know how can I configure a promotion workflow?
    thanks.
    avillanueva
    23-Emerald II
    Mar 11, 2025 1:43 PM UTC
    I would start by looking at online help documentation around workflows and workflow programming. Are you using the promotion workflow currently or are you just using set state? Workflows themselves are not hard to modify and edit but there is a ton of information and best practices out there. Skills needed for what you are asking for would be workflow customization which is Java programming and understanding the Windchill API.
    Fadel
    Fadel23-Emerald IIAnswer
    23-Emerald II
    Buiꓘa
