Save Administrator Time by Using the Windchill PTC System Monitor
- May 8, 2012
- 2 replies
- 2169 views
The Windchill PTC System Monitor (PSM) is a relatively recently available tool available from PTC (for free) which gives an administrator unprecedented Windchill monitoring and performance diagnostic capability never available previously. The intent of PSM is to :
- Increase visibility by administrators into the health of the system
- Reduce time to resolution of performance and other types of problems
- Reduce the time required for administrator to work on a problem with PTC Technical Support
It is highly recommended all customers install and use the PTC System Monitor.
The attached is a covers some of the highlights of PSM.
PSM can be downloaded from here.
