Scrolling Doesn't Always Update?
  • March 2, 2010
  • 647 views
Using Pro/Intralink 9.1 M030 with the embedded browser in Pro/Engineer Wildfire 4 M110. Internet Explorer 7 is the default web browser on my system.
I've noticed several occasions that when I'm dragging the scroll bar in Pro/Intralink, the data that it is showing in the tables doesn't always update (e.g. Workspace Object List that contains more than a screen-full of CAD Documents). I have to continue dragging the scroll bar, or click the up/down arrows at the top/bottom of the scroll bar a couple of times to get the data in the tables to refresh.
It doesn't happen all the time, but it happens more often than just being a coincidence. Can't seem to reproduce it on-command.
Anyone have any ideas if this is an Internet Explorer issue? Apache? Tomcat? Windchill? Something else?
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
Hi Andrew,
we just switched to WC9.1 m040 (from 9.0) and noticed the same behavior you are describing. I would relate it to Java version. I upgraded it to Java 1.6.0_16, but because it is not reproducible all the time, I am not quite sure if it solves it. Let me know if anybody figured out a solution for this
