Set an alert for workflow task.
  • March 11, 2013
  • 1093 views
Hi all,
I need to set a popup message based on a certain condition.Like if a & b are workflow variables and a>b..there will be a popup message "üpdate a".
How do i achieve that???
Best answer by GregoryPERASSO
Hello
In the workflow task, in the transition tab. for example the transition "complete" if you have only one vote possible in the task.
add some java code to test your variables, and if test is KO. throws a WTException with a String message on it.
it will display a popup with the error message to the User when he will try to close the task ...
regards
Gregory
GregoryPERASSO
Hello
regards
Gregory
