Jan 23, 2024 6:37 AM UTC
Set the default unit of the component, windchill12
The default unit cannot be set. Currently, unit.rbinfo and the corresponding attribute type have been modified to set the unit default value, but the default for creating components is still ea.
Translated by the Community Moderation using Google Translate
不能设置默认单位,目前修改了unit.rbinfo以及对应的属性类型中设置了单位默认值,但是创建部件默认还是ea
Jan 23, 2024 8:00 AM UTC
Similar issue - "Default Units for quantity": https://community.ptc.com/t5/Windchill/Default-Units-for-quantity/td-p/7361
avillanueva
23-Emerald II
Jan 23, 2024 12:34 PM UTC
If this is Creo created BOMs, ea is the default. Are you referring to simply creating a WTPart from UI and its no respecting the new default? BTW, what is your new default unit?
