Solidworks Workgroup manager
  • July 18, 2012
  • 2 replies
  • 931 views
Have you ever been able to make the Solidworks wokgroup manager work with
PDMLink ?
Here are the version used: PDMLink 10 / SOlidworkd 2012.
Is there any "traps" or "hidden tips" that may allow us to get such a
system working ?
Thibault Magné
Thanks for that. Do you know if there is a specific licensing (like Catia
WGM) and a documentation on server-side installation (if required) ?
Thibault Magné
2012/7/18 Figarotta, David <figarottad@enser.com>
> Should not be a problem. Did you check the compatibility matrix with the
> version of SEX 2012 and PDMLink 10 and build code?****
> Dave****
> David Figarotta****
> PLM Specialist****
> (O) 856.829.5522 x353****
> (F) 856.829.5748****
> (C) 215.806.9272****
> www.enser.com****
> *From:* Thibault Magné [
> system working ?****
> Regards,****
> Thibault Magn鼯div>****
We have successfully done this. However as of late I find that I have to do the install thru the DOS command setup instead of the Java installation.
Try downloading the Client Installer and install thru the DOS prompt.
