Sorting folder table in 9.1M050
hello
Does anybody have any information when PTC will sort basic issues such as been able to sort correctly table.
We had that problem in 9.0 but they knew we wanted to update to 9.1. So they never send us a fix. Now we are in 9.1 and the problem is still not fixed. Windchill cannot sort folder table correctly (1 sort or up to 3 sort) for attributes with values. It considers it is text.
If you sort by one column you have something like this
1
1.2
1.3
10
10.5
11
2
2.1
20
etc...
When you sort with 2 columns things are getting worse and I spare you an example.
As you can imagine this generate a lot of confusion, errors and risk that somebody takes the wrong decision.
Do you have the same issue on your system ?
Thank you
