Spreadsheet of Performance Articles in the Technical Support Knowledge Base
- June 25, 2012
- 2 replies
- 1840 views
Attached is a spreadsheet containing all of the Windchill articles relating to Performance which have been published to the web along with their relative 'reuse' rate. An article is considered reused when it is linked to a case. It doesn't mean that article led to the case resolution but rather it part of the work done for that case. One case can be linked to multiple articles.
Is having data in this format helpful, and would you have interest in seeing similar data for areas beyond Windchill Performance? I'm interested in your perspective please leave a comment below or send me an email with your thoughts.
