SQL 2005 with PDM Link 9.1
  • May 13, 2010
  • 3 replies
  • 1219 views
PTC documentation states that SQL 2005 is supported in M050+, however,
only if Windchill is on a Linux box. Does anyone know if the
configuration utility on the M050 software is Windows based (.exe)?
We've run into an issue that requires the purchase of additional
hardware and/or software licenses. Therefore we are trying to determine
the best path forward. We're trying to get this issue squared away
ASAP.
Thank you.
Dave Figarotta
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender immediately. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of Enser Corporation. Finally, the recipient should check this email and any attachments for the presence of viruses. Enser Corporation accepts no liability for any damage caused by any virus transmitted by this email.
Enser Corporation, www.enser.com
Footnote in the M050 matrix:
SQL Server is only supported with Windchill running on Windows prior
to M050. At M050, SQL Server is supported with Windchill running on
AIX and Linux.
To be clear, this means M050 supports SQL Server for Windchill running
on AIX and Linux /in addition to /the platform(s) supported prior to
that point.
Yeah SQL Server 2005 SP2+ has been supported way back into 9.0, let alone 9.1 M050
Steve Vinyard
Application Engineer
[cid:image001.gif@01CAF2B5.06566C90]
