sqlplus login issue
  • July 11, 2013
  • 2 replies
  • 968 views
After installing a patch to my oracle 10g database I get the following error when trying to log into sqlplus
ORA-01034: ORACLE not available
ORA-27101: shared memory realm does not exist
Any ideas?
Thanks!
It seems like the Database is closed.
Login as sqlplus /nolog and then as sysdba to start the database.
The full commands would look like below
sqlplus /nolog
connect sys/change_on_install as sysdba;
Connected to an idle instance
Startup;
