SUMA Bom report, adding reference designators
  • May 29, 2012
  • 644 views
PTC was kind enough to provide me the java code that generates the AML/AVL boms and an example of how to extend it. I can add any additional WTPart attribute, but am not sure how to get the Ref Des, which i believe are stored on the usage link.
If anybody has any suggestions, or snippets, I'd appreciate it.
Steve D.
avillanueva
23-Emerald I
May 30, 2012
import wt.part.ReferenceDesignatorSet;
import wt.part.ReferenceDesignatorSetDelegateFactory;
import wt.occurrence.OccurrenceHelper;
import wt.part.PartUsesOccurrence;
import wt.part.WTPartUsageLink;
private String getRefDesString(WTPartUsageLink link) throws WTException
String refDes=";//do not return null string, easier to code
QueryResult
result=OccurrenceHelper.service.getUsesOccurrences(link);
if (result.size()>0)
List<string> list=new ArrayList<string>();
while (result.hasMoreElements())
Object o=result.nextElement();
if (o instanceof PartUsesOccurrence)
PartUsesOccurrence puo=(PartUsesOccurrence)o;
list.add(puo.getName());
ReferenceDesignatorSetDelegateFactory factory=new
ReferenceDesignatorSetDelegateFactory();
ReferenceDesignatorSet set=factory.get(list);
refDes=set.getConsolidatedReferenceDesignators();
return refDes;
