Trying restore vaults from source environment by db import
The situation is that, I have completed the upgrade from 10.0 to 10.2 by keeping vault option ias " Do not modify vault configuration
" in upgrade manager utility. current the target system is working fine, but I before starting upgrade I had removed source vault configuration becuase it was pointing to out staging\acceptance environment vault.
Now I am trying to retore those configuration by doing a DB import as there are lot of folders are present.
I have imported following tables for this pupose.
- FVHOST
- FVFOLDER
- FVITEM
- FVMAOUNT
- REPLICATEDITEM
- REPLICAMOUNT
- REPLICAFOLDER
- ROOTMOUNT
- ROOTFOLDER
SITE table is having only one entry and is of master site and vault is located in another host.
After this the MS is getting up but when I tried to access the "external file vault administrator" page then I am getting a pop up saying " You are not authoriosed to acces this page"
and in MS log I am seing following error messages
wt.fv.FVHOST: invalid identifier
TYPEADMINISTRATIVEDOMAIN: invalid indetifier
I amnot understnding, is this really possible or if yes what step i am missing? is there another way to resotore source 10.0 vault configuration??
amny suggestion would be helpful.
