UIValidationStatus.ENABLE for Baseline
  • November 25, 2013
  • 0 replies
  • 984 views
Hi all,
I am trying to enable the unlock and edit actions of a "baseline" through a expression robot on the workflow.
What happens is that when I perform the lock (of the baseline) with a user, just this user or the adminstrator can do the Unlock.
I know tha is a UI Validation because when I use the jcaDebugg tool I can see and use the unlock and edit actions menu.
The problem is that I am newbie with Java I would like a help with the code to be used on the expression robot.
I found the code bellow, but this do not validate on the expression robot.
public class SelectorValidator extends DefaultUIComponentValidator
@Override
public UIValidationResultSet performFullPreValidation (UIValidationKey validationKey,
UIValidationCriteria validationCriteria, Locale locale)
throws WTException {
UIValidationResultSet resultSet = new UIValidationResultSet();
UIValidationStatus status=UIValidationStatus.ENABLED;
UIValidationResult result=new UIValidationResultSet(validationkey,status);
resultSet.addResult(result);
return resultSet;
Please some one could help me with this?
