Jun 18, 2025 5:44 AM UTC
Using Flexibility
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.12
On one set of Creo is mounted another set with flexibility to use variants (2 options).
When we check-in in Windchill using a variant it archives the 2 options duplicating the Assembly.
How can we make it archive the chosen flexibility option without duplicating the assembly?
    Jun 20, 2025 12:46 AM UTC
    Have you looked at this
    Visualization > Dynamic Structure > Display representations from image associated EPM documents to Yes
    Emeritus
    Jun 25, 2025 5:55 AM UTC
    Hello @ajuanjo,
    You have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
