Using InfoEngine to get Part classification information
Im trying to get the classification.path attribute values associated with a given part. Issue CS166604, on the PTC support site seems to suggest that you can do this by passing in ALL_SOFT_CLASSIFICATION_ATTRIBUTES as the attributes parameter on the Query-Objects webject. This does not work for me. Prior to 10.2 you seem to have been able to use classification.path but that seems to no longer work since according to them... "The data model for classification has changed and the old classification infrastructure is no longer used in 10.2" . Passing in "Classification" as the attribute parameter returns the class name but I need the path. Does anyone have any ideas on how to get the classification path?
