Verifying that the required Soft attributes (IBAs) have values set using API
All,
Does anyone have examples of enforcing the required attributes (IBAS)for
items (IBAHolders) through API?
Use case: Items are loaded through the OOTB Load utility where it many
not enforce the required soft type attribute constraint or legacy items
that do not have these values set.
Potential solution: Verify that the items have valid values for the
required attributes before Releasing them through the Change process.
Raju Pulavarthi
Raju Pulavarthi
