Visualization Representation Failed.....
  • June 30, 2014
  • 6 replies
  • 3097 views
Hi All,
I am using Windchill 10.1 M040 with Creo Parametric 2.0. When I am pulishing to create a new representation using windchill it always fails with the log. Whenever I checked in from Creo Parametric its successfull. In Windchill the CadWorker is configured properly and run successfully how ever I can't generate the new Representation for the files. the log is below. kindly help. i tried it also using Administrator but always fail. the CadWorker is running.
ul 1, 2014 12:55:04 AM:make temp dir D:\ptc\Windchill\Windchill\temp\pubtemp\publish7689743143708481417.tmp
Jul 1, 2014 12:55:04 AM:Start Job: Assembly - chair.asm, 1.1
Jul 1, 2014 12:55:04 AM:"As Stored" Config Spec is available
Jul 1, 2014 12:55:04 AM:The EPMDocument As Stored Config Spec was selected as the default
Jul 1, 2014 12:55:04 AM:Start: Assembly - chair.asm, 1.1
Jul 1, 2014 12:55:04 AM:Authoring Application: Creo
Jul 1, 2014 12:55:04 AM:Use Extended Positioning Assembly Processing
Jul 1, 2014 12:55:04 AM:Transferring Files to: D:\ptc\Windchill\Windchill\temp\pubtemp\publish7689743143708481417.tmp
Jul 1, 2014 12:55:04 AM:Error: Unable to Authenticate. Contact your system administrator and review the Method Server log for more information.
Jul 1, 2014 12:55:04 AM:Number of Files (identified to be) Transferred: 0
Jul 1, 2014 12:55:04 AM:No content to process
Jul 1, 2014 12:55:04 AM:End: Assembly - chair.asm, 1.1
Jul 1, 2014 12:55:04 AM:End job (with error): Assembly - chair.asm, 1.1
Jul 1, 2014 12:55:04 AM:Publish Complete event dispatched
Jul 1, 2014 12:55:04 AM:remove temp dir: D:\ptc\Windchill\Windchill\temp\pubtemp\publish7689743143708481417.tmp
Best answer by shussaini
Just create a file with name as auth.properties(file extension should be .properties) and place it under WT_HOME/codebase folder. Within the file specify the admin user in the following format
auth=admin_user:auth_password. Example, if admin user is wcadmin and password is wcadmin following will be the format
auth=wcadmin:wcadmin
Restart the worker and initiate the publishing again.
Hope that helps.
Regards
~Syed
Usually something to do with your auth.properties not being setup correctly.
nnaeem1-VisitorAuthor
Hi Stephen,
Thanks for the prompt reply. Can you please how can I setup the property. No idea about this as also the Site Administrator is unable to perform this job. Kindly share some material refernces if have.
Your help will be highly appreciated.
Regard's
shussaini16-PearlAnswer
Hope that helps.
Regards
~Syed
