Watermark rev of wt.part on the published drawing
  • November 5, 2013
  • 34 replies
  • 21017 views
I am hoping somebody already figured it out, and it is not a costly customization...
22-Sapphire I
November 5, 2013
Your terminology is a bit confusing. Do you mean WTPart or (CAD) .PRT?
We include Drawing Number, Name & Version in the watermark. This uses standard watermark configurations (we hard branch to watermark file with state hard coded because this was buggy in the past; may revisit). A printed / emailed drawing is traceable to a single object in the system.
Dmi3U15-MoonstoneAuthor
Here is to clarify:
The watermark is applied by CreoView/WVS publishing.
The Rev of the WTPart is needed to be on the watermark as well as the date of the release change - we might have rev of the drw different from rev of the WTPart (example: multiassembly drawings)
In Reply to Dmitry Ushamirsky:
Need Help. 1st time trying to implement watermarking for DRW Printing & Viewing.
I followed the ptc tans/tpis/etc & still not working. Below is my prefs file. Attached is my ini file (asf_01.ini).
I would also like to add date & Version, but have not found the proper property. Only found "epmdoc_lifeCycleState".
I have also attached what the General/Watermark preferences & mapping are set to (image prefs.jpg).
server_prefs.xml also attached.
Any help would be appreciated.
Larry Jett
datajett@aol.com, cadjett@aol.com
I forgot to attach an image of the settingsfor: Visualization Configuration Administration - Site (viscfg.jpg).
Larry Jett
22-Sapphire I
February 10, 2014
One approach (which we use) is to have a number of watermark files, and to have the system select the one needed at the time of viewing - based on current lifecycle state of the parent object. This requires no coding - just configuration thru the Creo View GUI and loading of the resulting text file.
You can have the system use one of a variety of criteria to select which watermark file to apply; in our business, lifecycle state is the only one that makes sense.
[cid:image001.png@01CF263F.FC9EE2A0]
[cid:image002.png@01CF263F.FC9EE2A0]
Note: This benefits greatly from some good discussion with all affected parties. One can choose to
* embed the watermark in the viewable at the time of publishing, or
* select and apply it at the time of viewing.
Embedding it of course requires re-publish after each state change.
Selecting and applying at the time of viewing is elegant and in our opinion the only way to go.
Need to prepare multiple watermark files and load them here
[cid:image003.png@01CF263F.FC9EE2A0]
This stuff is not necessarily all that evident from PTC documentation...
Thanks Mike,
Look at my attached files, because I think I am doing what you suggest. But just for simple DRW to show LC State & Date.
Then eventually add Version (dont know the property for that yet. cant find it in support search).
You showed option:
I am trying to set this up to add watermarks for all DRW PDF's published.
I cant get the watermark to show anywhere. When publishing or just viewing. I am probably just one step off.
Larry
I did find the properties for Revision & Date:
I am placing them in this message, so others can find them in future searches.
I also attached an excel with them enclosed:
epmdoc_creatorName
WindchillEPM
user name
epmdoc_modifierName
WindchillEPM
Administrator
epmdoc_instance
WindchillEPM
FALSE
epmdoc_cabinetName
WindchillEPM
Default
epmdoc_templated
WindchillEPM
FALSE
epmdoc_businessType
WindchillEPM
EPMDocument
epmdoc_organizationName
WindchillEPM
XXX
epmdoc_modifyTimestamp
WindchillEPM
2014-02-10 09:43:52 CST
epmdoc_versionInfo
WindchillEPM
B
epmdoc_folderingInfo
WindchillEPM
/Default/XXX
epmdoc_name
WindchillEPM
FILL/EXTERNALXXX MANIFOLD
epmdoc_hasVariance
WindchillEPM
FALSE
WindchillEPM
Design
epmdoc_CADName
WindchillEPM
XXX09008.drw
epmdoc_generic
WindchillEPM
FALSE
epmdoc_verified
WindchillEPM
TRUE
epmdoc_docType
WindchillEPM
Drawing
epmdoc_displayIdentity
WindchillEPM
Drawing - XXX09008.drw,
B.2
epmdoc_defaultUnit
WindchillEPM
each
epmdoc_formatName
WindchillEPM
NONE
epmdoc_hasHangingChange
WindchillEPM
FALSE
epmdoc_createTimestamp
WindchillEPM
2013-12-12 09:12:05 CST
epmdoc_containerName
WindchillEPM
XXXYYY
epmdoc_lifeCycleBasic
WindchillEPM
TRUE
epmdoc_collapsible
WindchillEPM
FALSE
epmdoc_topGeneric
WindchillEPM
FALSE
epmdoc_hasPendingChange
WindchillEPM
FALSE
epmdoc_creatorEMail
WindchillEPM
xxx@YYY.com
epmdoc_number
WindchillEPM
XXX09008.DRW
epmdoc_lifeCycleName
WindchillEPM
XXX_LC
epmdoc_iterationDisplayIdentifier
WindchillEPM
B.2
epmdoc_ownerApplication
WindchillEPM
Workgroup Manager
epmdoc_missingDependents
WindchillEPM
FALSE
epmdoc_derived
WindchillEPM
FALSE
epmdoc_modifierFullName
WindchillEPM
Site, Administrator
epmdoc_creatorFullName
WindchillEPM
last name,first nme
epmdoc_qualifiedidentifier
WindchillEPM
B.2
epmdoc_revisionNumber
WindchillEPM
144
epmdoc_authoringApplication
WindchillEPM
Creo
epmdoc_placeHolder
WindchillEPM
FALSE
L Jett
Lawrence,   I know this is an old thread, but this post with the epmdoc variable names and examples was a huge help for me along with your attachments.  Just wanted to say Thanks
So the title of this thread is "Watermark rev of wt.part..." but so far I have only seen solutions for watermarking EPMDoc properties on the drawing. Does anyone have a solution for watermarking associated wt.part information on the drawing?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CF2668.6B805320]
22-Sapphire I
February 10, 2014
As far as I know, the viewable of the associated EPMDocument (either drawing or 3D model - configurable globally) is mapped to the WTPart and displayed. No attributes from the WTPart are part of what is displayed in CreoView.
HI Dimitry,
I know that someone who figured it out. I don't think it is costly customization and I thinkthey are pretty affordable. It called the "Stamper" and PLM Worker from Najanaja.com. It is a great self-configurable architected framework that you can query any application (i.e. Windchill) up and down objects to be placed on the drawings as a watermark. I really like the flexibilty of the framework.
I've used Najanaja in the past and had no issues with their support and amazing work. Some many other big companies have used Najanaja as well. I wouldn't waste my time and money with other companies with false promises that has no experience with standard requirements and windchill proper architecture. If you have a tight budget, timeline and want the best custom solutions,give them a shout. Because we all have tons of experience implementing Windchill, I have no issues passing my requirements to them with instant sync'ing of knowledge of business requirements, architectual soluions and expected results. When you have to start to teachthe consulting company how to properly look into up and down Windchill architecture, then you know you should be looking elsewhere. I don't have that issue with Najanaja.
http://www.najanaja.com/?q=products
Patrick
